‎01-17-2006 06:28 AM
‎01-25-2006 09:38 AM
The NI PCI-4461 has been released making it the highest-performance dynamic signal acquisition (DSA) board on the PCI bus with a 118 dB dynamic range. The release also includes the National Instruments LabVIEW Sound and Vibration Toolkit Version 4, with 10 new Express VIs for simplified application development. These new products add to the comprehensive NI hardware and software tools for sound and vibration applications, including PXI, PCI and USB measurement devices and powerful, easy-to-use analysis software.
In addition to 24-bit output channels on PCI, the PCI-4461 DSA board offers two 24-bit input channels, making it ideal for stimulus response applications such as audio and structural tests. The input-only version, the NI PCI-4462, provides four 24-bit input channels and a 118 dB dynamic range. Engineers can synchronize multiple PCI-4461 and PCI-4462 boards to attain four-input and four-output systems or six-input and two-output systems for applications such as simultaneous 5.1 speaker surround sound test or acoustic holography. Both boards also feature IEEE 1451.4 transducer electronic data sheet (TEDS) capability, which simplifies the configuration of a microphone or an accelerometer measurement. Like the PXI-4461, the PCI-4461 has BNC connectors and does not require a breakout box like the PCI-445X.
The NI LabVIEW Sound and Vibration Toolkit 4 now is easier to use with 10 new Express VIs for interactively developing applications and generating code for fractional octave analysis, frequency response, vibration and sound level and other common analyses. Engineers can customize applications such as integrated vibration level measurements, weighted sound level measurements, swept sine analysis, power spectrum analysis, limit testing and transient analysis.
‎02-22-2006 09:33 PM
‎02-23-2006 09:19 AM
There is a good note about how to do this in the NI KnowledgeBase called "Multidevice task support for DSA devices."
http://digital.ni.com/public.nsf/allkb/78E44565FD87E7D686257108007F94F8
DAQmx has the ability to create taks that span multiple devices. When you include channels from multiple DSA devices in a task, NI-DAQmx automatically synchronizes the devices.
A task can include channels from multiple DSA devices, given the following conditions:
For all DSA devices:
For PXI Devices:
PCI Devices:
