Dynamic Signal Acquisition
How can I use FRF function after i have collected the raw data?
I have collected a set of raw data from a vibrational test. I didn't save the FRF results. I was wondering if i can do a FRF post data analysis. Maby by using a modified verison of the FRF (SVXMPL_Baseband FRF (Simulated).vi found in the NI example finder with sound and vibration toolkit) to read my data (two columns: Stimulus, Response) knowing that i have saved the settings (i.e. sine wave, sample rate, frequency resolution....). This example porgram from NI generates the signal on its own and doesn't allow me to import data.
thank you
cheers
Wafa
PS. the test cannot be repeated, i have modified my program that it can now save the FRF results.
(6,525 Views)
I figured it out...removed the data generator in the stimulation and used my saved data (after lots of modification) into the program...works perfectly now...
(6,512 Views)
