10-15-2009 03:49 AM
10-15-2009 03:52 AM
		10-16-2009
		05:02 AM
 - last edited on
		07-22-2025
		08:09 AM
 by
			Content Cleaner
Hi Giakko,
your connections are correct if you perform a differential acquisition.
Try to acquire the signal in Measurement & Automation Explorer to see if the problem is still there.
Verify with a scope your signal to see if it is noisy at origin.
Also try to short AI0 and AI8 and verify if 0V are correctly acquired or if the card has some problems.
I also suggest you to read this tutorial, which is really detailed, about the correct connections for different signal sources and possible techniques to reduce noise.
I hope it will help!
Bye!
Licia
10-22-2009 05:29 AM
How long are the cables?
What type of cable?
Shielding, grounding?
What banwidth do you need?
What's the resistor value?
Can you use a transimpedance amplifier to get a low impedance signal?
10-22-2009 05:42 AM
10-23-2009 02:06 AM
Giakko wrote:
Hi, I included a capacity (10microF) to the resistor (1,2Mohm) to cut high frequencies. Now the signal is clean. thanks for your help.
Just some notes:
Have you checked/thought of the leakage current of that capacitor?
A 100mV Signal is just 83nA and eletrolytic caps can go easely in that direction.
Have you checked the input impedance of your DAQ? Just had a look.. OK 10G is fine 😉 However how about the BIAS current? 100pA x 1M2 = 0.12mV sounds fine ....
Have fun
