Dynamic Signal Acquisition
Wrong info about PCI-4452 on Catalog 2005?
Hi. I found that on page 254 of Catalog 2005 there's a table where it says that NI PCI-4452 has IEPE conditioning. Is that true?
Daniel Ramírez
MSc - Mechanical Engineer
Universidad de Concepción
(6,831 Views)
The PCI-4451 and 4452 do not have IEPE conditioning built-in to the board itself, but the BNC-2140 does. If you need IEPE conditioning, this is the terminal block that you should choose with the PCI-4451/2.
Sorry for the confusion.
-Jack
(6,828 Views)
Thank you. It's just that it can be a little confusing. Specially when the connector block is not mentioned in the table.
Daniel Ramírez
(6,823 Views)
