FOUNDATION Fieldbus
Configurator 3.2 is not seeing my device
I am replacing an old NI 2.3.6 Communicator / PCI Card / Configurator system, and I have everything in place, but the Configurator. First off, the registration does not complete, and I am attempting to at minimum set it up in evaluation mode. I have loaded my DD through the Configuration utility - which does see my card. Dialog works fine. However, when I start Configurator, I get no communications. It doesn't even see my FF device.
(6,695 Views)
You have to activate the Configurator to see the online devices. The evaluation version can only use Offline mode.
Tell me the part # of the Configurator 3.2 you purchased. For the activation, you can send email to fieldbus.support@ni.com for help.
Ryan Shi
(6,685 Views)
