muks asked " ...what is that?"
"Quick-Drop Tutor"
It is a VI that I started writing on Friday night so that I can haness the power of the new Quick-Drop (QD) function that is now built in to LV 8.6. Quick drop lets me define short-cut key sequences to drop LV operators on the diagram. Example:
I hit the key-comb "ctrl-space" to bring up the QD dialog...
type "ab" and click on the diagram and a "Build Array" node appears on the diagram.
I have determined which functions I use most often and have developed a set of short-cuts for them. The QD Tutor will (eventually) run in three modes.
1) review mode - It displays one of my operators and let me try to remember the short-cut. I then press a button and it shows me the correct short cut (done).
2) Tutor Mode - It will show me the image and I have to type the correct short-cut. Any short-cuts i get wrong get put back in the stack, else that icon will not be shown again.
3) Time-Mode - It will show me the icon and time how long it takes for me to get them all correct.
After I have trained myself I hope to be able to develop diagrams (quoting my wife ) "bloop, bloop, bloop".
Ben
