Feedback on NI Community
Naming the Next Rank
I blink, JLV posts and the next thing you know there are 15 new replies to this thread! Smiley Surprised
Becktho wrote "Anyway - this whole thread is about what comes after the PEV and not before."
I agree.
It also appears that we are falling into step behind Dennis' stated preferences.
It also appears we have differences of opinion about distrubing the system up to the PEV level.
I would therefore propose (you have the right to over-ride) that we table discussion of the ranks up to PEV and focus on titles for above PEV.
I would like to repeat the idea of completely dropping the bars afte PEV and replace it with an icon that implies the Knightly nature, I'm thinking of a shield or family crest type thing.
If I can find time maybe I'll try to cobble together a repesentative image.
If I understand coorectly, Laura has reserved the right to select what the threshold will be.
Excellent Exchange All!
Ben
Message Edited by Ben on 11-08-2006 07:57 AM
Message 61 of 127
(4,697 Views)
Something like this?
Message Edited by AdamB on 11-08-2006 08:17 AM
Applications Engineering Team Leader | National Instruments | UK & Ireland
Message 62 of 127
(4,692 Views)
Great one AdamB, but the icon should give the possibility to easily to differ between the different orders.
Ben, I can double your statement - Knights of NI is my choice (although I probably never will go for one of those ;)).
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 63 of 127
(4,674 Views)
Nice start Adam!
But now I want to suggest "Knight of NI Order of the Blue Eagle" for >10K.
Ben
Message 64 of 127
(4,684 Views)
Ha ha,
Good call Ben.
Different background colours (and differnt colour swords too) could help.
OR
different images on the sheild.
Order of the Duck (Duck on the shield)
Order of the Trojan Rabbit (yep you guessed it a rabbit)
and finally the eagle for 10K plus.
AdamB
Message 65 of 127
(4,676 Views)
Excellent points everyone!  This discussion is great!
First I want to comment on the idea of adding a new rank at 1000 posts:  Although this is something I want to do, it can't be implemented right away.  The main reason is one that is mentioned - I don't have an icon for it!
However, I do have an icon for the rank above PEV.  It's still a set of bars, so I think it would make sense to follow the Proven _____ Veteran template.  Plus, I feel we don't want to leave this template behind at a level that is too low or in the future it won't carry as much weight.  We still want people to be excited to become Proven Enthusiastic Veterans because it is quite an accomplishment!
After that rank, I see switching to a different system like "Knights of NI" to be a possibility, since everyone seems to like it so much.  It will take a little while for me to get an icon for that as well, so that will come in the future.  For now, let's vote on a name that fills in the blank of Proven ______ Veteran that would be implemented for 5,000 posts.
I look forward to more ideas!  Smiley Happy
Laura
Message 66 of 127
(4,670 Views)
For this rank, I like Ben's idea : Proven Altruistic Veteran
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 67 of 127
(4,661 Views)
Wow - 5K. That's quiet hard to reach. Ok, it should werk for a long term base but how likely is it to that every community member gets to 5K? I think the distance from PAV to PEV is ok to separate the wheat from the chaff, but afterwards the next step should not increase like this. If the PxV will be reached with 5K, what is the value for the first Knight? 10K? The second order at 20K?
I think the gap between the different levels should not be to big.
Using LV8.0
Message 68 of 127
(4,657 Views)
I thesaurused some of these and came up with a few I like "Addict", "Maniac", and "Fanatic".
Ok ok I think that the altruist is good, however if there is going to be another rank over altruist what would that be, "God"?
If this is a temp renaming while we change over to a new system, possible the Knights method, then its not as big of a deal.
Message 69 of 127
(4,630 Views)
Right well I trawled through the posts and found the below suggestions so far. Some better than others Smiley Wink
Proven Passionate Veteran
Proven Unstoppable Veteran
Proven Obsessed Veteran
Proven Ebullient Veteran
Proven Devoted Veteran
Proven Zealot (Zealous) Veteran
Proven Post-o-matic Veteran
Proven Addicted Veteran
Have I missed any?
What are your feelings on these?
AdamB
Message 70 of 127
(4,620 Views)
