Feedback on NI Community
Problems uploading a ZIP file
And add LLB to the list of things I can't post.
Message 11 of 88
(7,811 Views)
Trying a ZIP file upload with Android tablet.
and that  is OK
Message 12 of 88
(7,795 Views)
I was just able to post a zip file.  Granted, I am on a different computer than before.  But the software specs are the exact same.
Message 13 of 88
(7,773 Views)
To add to the strangeness, I was blocked from posting a VI, but was allowed to post a zip of it.
Message 14 of 88
(7,759 Views)
ZIP upload from another computer also fails.
But a VI upload is OK.
We could make a table with who can upload what and mail to files to each other  Smiley Very Happy
Hope this is solved soon.
Message 15 of 88
(7,749 Views)
Let's give this a little bump since it still seems to be going on.
Why hasn't Lithium recognized and figured out the problem?  It seems like a kind of file/virus scanner problem.  They must have made some sort of change to their system that directly correlates to when these problems started happening.
Message 16 of 88
(7,696 Views)
I guess they added a malware scanner that inspects the zip contents, but that thing is not programmed in LabVIEW and thus cannot be debugged that easily. 😮 😄
Message 17 of 88
(7,686 Views)
I just received word the issue is due to a bug in the application, but it's been fixed. The community will be restarted tonight to pick up the fix and the issue should no longer be a problem. I will test this evening, but please let me know if you are still having issues posting attachments tomorrow.
Jordan
Message 18 of 88
(7,660 Views)
Testing for a ZIP, LLB and VI upload.
It works if the files are OK. e.g. a file with a extension VI which is not a valid VI cannot be uploaded. Just mention it here but it is not a real problem for me.
Thanks Jordan for the solution.
Kees
Message 19 of 88
(7,648 Views)
That still seems buggy. See for example here
When I try to attach my VI, I get the error "file contents don't match file type"
This should be investigated. Could it be a VI in a very old version or from a different platform?
Message 20 of 88
(7,635 Views)
