‎01-30-2014 08:59 AM
I zip up my VI to post. Seems to work well. But it is still highly annoying not being able to post VIs directly.
‎02-13-2014 01:51 PM
You should be using projects anyhow! ![]()
the build>>zip isn't too aweful
‎02-17-2014 12:58 PM
I'm seeing an error trying to attach a .png file "The contents of the attachment doesn't match its file type". It worked just fine last week. I was trying to upload to this thread Boolean properties window cosmetic glitch
‎03-13-2014 07:56 AM - edited ‎03-13-2014 07:59 AM
BUMP!
Another 6 weeks later, same problem as can be seen here today...
I still need to rename my VI attachments to *.vit or else "The contents of the attachment doesn't match its file type."!
Writing messages now with FF27.0.1…
‎03-13-2014 10:55 AM
Every so often, I try to post a VI file. I think it has been about a week, but still failed for me as well. I'm just in the habit of zipping up VIs before posting them. At least it saves server space.
‎03-17-2014 04:54 AM
‎04-04-2014 02:06 AM
‎04-12-2014 03:31 AM
Same with me (using FF 28.0): I could not any VI or zip to this post and had to inline VI snippets.
‎04-22-2014 02:01 AM
BUMP!
The same old problem is also annoying members of NI R&D here!
Maybe you could have some in-house discussions on this problem - or even some in-house testing of your forum software?
We are heading for the anniversary of this bug. Should I prepare some pie with a candle? (Yes, that's sarcasm…)
‎04-22-2014 07:07 AM
Mmmmm...pie.
Yep, this annoying me that I can't post a VI file. Still have absolutely no issues with zip files though. (FF28, Windows 7 64-bit).
