Feedback on NI Community
Problems uploading a ZIP file
I zip up my VI to post.  Seems to work well.  But it is still highly annoying not being able to post VIs directly.
Message 51 of 88
(5,446 Views)
You should be using projects anyhow!  Smiley Very HappySmiley Very HappySmiley Very Happy  the build>>zip isn't too aweful
Message 52 of 88
(5,415 Views)
I'm seeing an error trying to attach a .png file "The contents of the attachment doesn't match its file type".  It worked just fine last week.  I was trying to upload to this thread Boolean properties window cosmetic glitch
Message 53 of 88
(5,391 Views)
BUMP!
Another 6 weeks later, same problem as can be seen here today...
I still need to rename my VI attachments to *.vit or else "The contents of the attachment doesn't match its file type."!
Writing messages now with FF27.0.1…
Message 54 of 88
(5,344 Views)
Every so often, I try to post a VI file.  I think it has been about a week, but still failed for me as well.  I'm just in the habit of zipping up VIs before posting them.  At least it saves server space.
Message 55 of 88
(5,332 Views)
BUMP!
Even getting more worse as documented here!
Message 56 of 88
(5,313 Views)
BUMP!
The same old problem here!
Now with FF28.0…
Message 57 of 88
(5,254 Views)
Same with me (using FF 28.0): I could not any VI or zip to this post and had to inline VI snippets.
Message 58 of 88
(5,220 Views)
BUMP!
The same old problem is also annoying members of NI R&D here!
Maybe you could have some in-house discussions on this problem - or even some in-house testing of your forum software?
We are heading for the anniversary of this bug. Should I prepare some pie with a candle? (Yes, that's sarcasm…)
Message 59 of 88
(5,189 Views)
Mmmmm...pie.
Yep, this annoying me that I can't post a VI file.  Still have absolutely no issues with zip files though.  (FF28, Windows 7 64-bit).
Message 60 of 88
(5,183 Views)
