Feedback on NI Community
Tag entry does not support CamelCase
I entered the tag "XNode" and it got changed to "xnode".
Please fix.
Ben
(4,626 Views)
Accepted by Ben
Hi Ben,
After looking into this, it appears that if you enter duplicate tags with different capitalization, the system will alter the newer tag to be identical to the existing tag. There was an existing "xnode" tag, which is why your tag was changed. Since, most tags on the Forums are using proper capitalization (e.g. LabVIEW), I went ahead and updated the tag to be "XNode".
This change should apply to all existing instance of the tag and any future tagging, so you should see your previous tag updated.
Let me know if you see any issues!
Matt
NI Community Team
(4,617 Views)
