Feedback on NI Community
Threads are floated twice
Laura, on occasion (I've seen this more than once) I float a thread and it appears twice in the list.
To solve this, I usually need to unfloat and float the thread until it works out.
It's interesting to note that, at the moment, the thread shown in the example appears in the floated list even though going into the thread gives me the option of floating it and not the option of unfloating it.
___________________
Try to take over the world!
Message 1 of 15
(7,790 Views)
Well, now it stopped appearing in the floated list, but now I floated it and it was only floated once.
This, of course, does not solve the problem since this is a recurring issue.
___________________
Message 2 of 15
(7,785 Views)
Hi tst,
Thanks for the bug report!
I have a question for you:  Does this happen only when you first float a thread?  Or, can it happen that you have floated a thread, it appears only once, and then you come back the next time and it is floated twice?  I will try to reproduce this and want to be sure that I am using the correct case.
Thanks!
Laura
Message 3 of 15
(7,778 Views)
I think this always happens immediately after I float a thread (it can happen several times in a row with the same thread, but it doesn't happen with all the threads).
I don't know if this is relevant, but I disabled the last column in the board view, so I have to float and unfloat the threads from within the threads themselves.
___________________
Message 4 of 15
(7,762 Views)
In retrospect, I don't think it is, because I'm pretty sure I remember that this also happened when I used the board view to float threads.
___________________
Message 5 of 15
(7,760 Views)
Hi tst,
I haven't seen this happen yet, but I'll keep trying.
Everyone - Does this happen to you?
Thanks!
Laura
Message 6 of 15
(7,709 Views)
I can't say I float threads all that much (since that thread, I only floated one more and it didn't do this), but I can say that this is not localized in time, since I remember it happening several times at least six months ago.
___________________
Message 7 of 15
(7,701 Views)
@Laura F. wrote:
Hi tst,
Thanks!
Laura
while trying out the float function, a similar situation occurred Smiley Mad ... but as tst described... after unfloating it and floating it again, it seems to be working well again Smiley Surprised ... and it does not happen all the time..
Message Edited by JQ on 01-23-2007 10:16 AM
Best Regards,
JQ
LV 8.0 user...
Message 8 of 15
(7,689 Views)
Hi JQ,
Thanks for the information!
Did you float this thread while looking at the thread, using the Thread Options menu?  Or did you float it by using the arrow in the board view?
Thanks!
Laura
Message Edited by Laura F. on 01-23-2007 03:53 PM
Message Edited by Laura F. on 01-23-2007 03:54 PM
Message 9 of 15
(7,672 Views)
Hi Laura,
I float it by using the arrow in the board view...
Message Edited by JQ on 01-24-2007 08:49 AM
Best Regards,
JQ
LV 8.0 user...
Message 10 of 15
(7,663 Views)
