Feedback on NI Community
Virus scan for uploaded files - and file size afterwards…
Hi GerdW and Crossrulz,
I could not reproduce the issue. Please try to clear your cache and see if this resolves the issue.
Best Regards,
Kristi Martinez
NI Community Support
Message 11 of 37
(6,582 Views)
Hi Kristy,
still the same problem - after clearing the cache several times. (Also on different computers.)
Message 12 of 37
(6,553 Views)
Hi GerdW,
Thank you for trying to resolve the issue on your end. I will continue investigating this issue for you. I will keep you updated.
Best Regards,
Kristi Martinez
Message 13 of 37
(6,544 Views)
Just now cleared my history and everything and still saw this issue.
Message 14 of 37
(6,529 Views)
Do you all see this issue with every post that has file attachments or is it intermittent?
Message 15 of 37
(6,515 Views)
I'll have to keep track to see if I see it on every post that has an attachment.  But I believe it happens pretty much every time.  I had never seen it happen before up until whatever change occurred a couple months ago.
Message 16 of 37
(6,535 Views)
Hi Kristi,
still the same issue:
right after postright after postafter virus scanafter virus scanafter refreshafter refresh
Message 17 of 37
(6,521 Views)
Thanks for the example, Gerd. I'm still unable to reproduce this in Firefox 67x or Chrome on Win 10. Are you seeing this issue on every post in which you include an attachment or is it sporadic?
We will pass this example along to our vendor though as they continue their investigation into the issue.
Lili
Message 18 of 37
(6,506 Views)
I am not certain if it is a post I am replying to or if the original post, but I am seeing it every time when one of those has an attachment.  The initial visible attachment in my post is that attachment(s) and then  the refresh corrects it to just mine.  I have even seen this go as far as to show my post having many attachments (again, matching the OP), when I just posted a single zip file.
Message 19 of 37
(6,503 Views)
Just got some confirmation with this post that the initial visible attachment is of the post I am replying to.  Nothing has changed.  See the issue on every post I attach something to.
Message 20 of 37
(6,450 Views)
