07-13-2012 02:04 AM
On these pages, for example:
https://decibel.ni.com/content/docs/DOC-17840
https://decibel.ni.com/content/docs/DOC-5958
The images and uploaded VIs are linked to https://decibel-test.ni.com/. This subdomain seems to be unavailable.
As result I can't see the screenshots, download VIs, etc.
For example, wrong path:
https://decibel-test.ni.com/content/servlet/JiveServlet/download/5958-2-8009/Scrub861_v3.zip
Correct path seems to be
https://decibel.ni.com/content/servlet/JiveServlet/download/5958-2-8009/Scrub861_v3.zip
Please fix it. Thanks.
Andrey.
Solved! Go to Solution.
07-13-2012 02:12 AM
I think this should be reported to the webmaster instead of forum admin, no?
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
07-13-2012 03:49 AM
Yes, you're right, but unfortunately I haven't found more suitable place for this issue. I hope forum admin can forward this to NI webmaster, then remove this topic from forum if necessary.
07-13-2012 03:53 AM
If you clic on "Contact NI" at the bottom of the page you then have different options, one of them being "Report a problem with ni.com"
Epictetus
08-13-2012 10:20 AM
This was issue was an acute bug in our system that was addressed and fixed. I apologize for the inconveniance.
Hassan Atassi
