Feedback on NI Community
inserting links became highly dysfunctional
Inserting and editing links has become very difficult with the new updates.
before the update:
  1. highlight some text
  2. press link button
  3. insert URL in the second field (after deleting the pre-existing http:// in that field).
  4. Press insert
  5. Link is fine, contains original text and points to URL.
now:
  3. Both fields will be empty (???)
  4. Enter URL
  5. Press insert
  6. ---> original text is lost!
editing a link is also no longer possible:
Click on an existing link and link button highlights as before, press the link button: all fields are empty (???)
(Before, the existing link and the link text were already filled in for convenient editing)
Message 1 of 13
(7,665 Views)
I guess in the process of finally fixing the presence of that stupid "http://" in the link field, they are now wiping all fields. 😮
Message 2 of 13
(7,651 Views)
Notice that the dropdown box for current window or new window is now gone as well.
Message 3 of 13
(7,647 Views)
Thanks for reporting this behavior, Altenbach and crossrulz. It looks like this bug is only affecting Chrome... which is interesting since in Firefox and IE the "http://" prefix is still there. I'll let Lithium know of the bug!
You guys are great!
Jordan
Message 4 of 13
(7,631 Views)
link test to this thread.
They have not... 'finally fix[ing] the presence of that stupid "http://" in the link field' on Safari on the Mac, but I agree fully with Christian's opinion of the pre-existing entry in that field.
Lynn
Message 5 of 13
(7,622 Views)
Lynn
Checking the link by quoting and editing Lynn's link.
When I edit the link,, the link URL box shows  /t5/Feedback-on-NI-Discussion-Forums/inserting-links-became-highly-dysfunctional/m-p/2155888#U2155888
But it winds up working.  I don't understand why because all of the forums.ni.com is missing.
(This is in IE8)
Message 6 of 13
(7,613 Views)
I see blank fields on the new version of FF (15.0.1).
___________________
Try to take over the world!
Message 7 of 13
(7,594 Views)
I'm also getting the issue with Firefox 15.0.1, Windows 7 64-bit
Message 8 of 13
(7,584 Views)
tst - are you using windows7 64 bit as well?
I am unable to reproduce the issue using FF 15.0.1, W7 32-bit. Would you be able to clear your cookies and cache and confirm the issue still persists for you, crossrulz? I've also informed Lithium you are experiencing this in FF. I'll work to reproduce it as well.
Jordan
Message 9 of 13
(7,563 Views)
Ok, clearing cookies fixed mine.
Message 10 of 13
(7,557 Views)
