03-25-2008 04:34 PM
Can you post a screenshot of MAX showing this? What versions of Labview and Fieldpoint are you using?
Not sure what this would be. All I can say is to check to make sure you have all the drivers installed on your PC. Fieldpoint, NI-VISA, ....
03-26-2008 06:35 AM
03-26-2008 08:24 AM
JeffOverton wrote:
I would assume that if you don't have the option of Remote Systems, it means your hardware is not hooked up or powered on.
03-26-2008 09:06 AM
"I would assume that if you don't have the option of Remote Systems, it means your hardware is not hooked up or powered on."
I have the FP-1000 & FP-AI-110 connected and from the FP-1000 using RS232 to the PC. I can monitor channels using Fieldpoint Explorer and see the network and access LEDs flicker amber when monitoring (otherwise they would normally be green). I just can't seem to get the FP modules and inputs to be recognized in MAX.
Version:
LabView v6.0, FieldPoint v3.0.0, MAX v2.0.3.6, NI-488.2 v1.6, NI-DAQ v6.8.0f9, NI-IMAQ v2.21, NI-VISA v2.5, Windows 95
Any recommendations?
Thanks!
03-26-2008 07:15 PM
Can you post a screenshot of your MAX? MAX 2.0 should still have a remote systems listing.
03-27-2008 06:34 AM
"Can you post a screenshot of your MAX? MAX 2.0 should still have a remote systems listing."
David, I the FP is connected to a Win95 box with no network connection, bad floppy drive, no cd burner and no usb. I don't have any way to transfer the screenshot. I can tell you that I have expanded everything in the tree and "remote systems" is not there.
Thanks.
03-27-2008 09:00 AM
03-28-2008 08:26 AM
03-28-2008 02:23 PM
