FieldPoint Family
FP-DO-403 outputs
I just bought this hardware along with various componets of Fieldpoint. Along with it is a cFP-TB-4. I am wondering how do I work with the output. I'm trying to make an output with 24 individual LEDs. Any assistance would be helpful.
Message 1 of 13
(5,007 Views)
Sorry if I didn't give the right information as I'm new to forums. However, I'll give the necessary info and hopefully you can guide me.
Message 2 of 13
(4,997 Views)
Please take a look at the Operating Instructions starting on page 3 for instructions on wiring load to your cFP-DO-403.  The Operating Instructions can be found online at: http://www.ni.com/pdf/manuals/323354a.pdf .
Please let me know if you have any further questions.
Sean C.
Message 3 of 13
(4,983 Views)
Yes, I have read the it but it only supplies one output. How do I split and as well control the voltages for each individual LEDs. Do
Message 4 of 13
(4,980 Views)
Yes, I have read the it but it only supplies one output. How do I split and as well control the voltages for each individual LEDs. Do i need to buy a new equipment to convert the output? I've already have a program that is created to control the 24 LEDs individually.
Message Edited by OTY on 08-18-2005 10:46 PM
Message 5 of 13
(4,985 Views)
OTY,
Though the diagram shows just one output, the rest 15 are the same.  You will connect to their respective terminals given on Table 1.
By the way, DO-403 has only 16 outputs, and not 24 as you mention.
-Khalid
Message 6 of 13
(4,973 Views)
Well, I got another unit as well with 8 outputs, which makes 24 outputs total. Unfortunately, I still do not get it. More specifically, where do I connect the output to? I'm sure I can't just connect the wires individually straight from the 37-pin. I'm also assuming that I'll be able to excess the terminals using the Labview's software.
Message 7 of 13
(4,973 Views)
With compact FieldPoint, you will need to use a Connector Block for each I/O Module.  For each DO-403 you have, you will need a cFP-CB-1 to access your signals.
You will have access to each DO Line from LabVIEW.
I hope this helps.
Sean C.
Message 8 of 13
(4,962 Views)
Thanks. Didn't know I had those parts. Now I just need a referrence for the wiring on the connector block. The manual said something about an I/O module operating instrutions which includes a diagram. Anyone know where I can get it?
Message 9 of 13
(4,955 Views)
The Operating Instructions for the cFP-DO-403 can be found at: http://www.ni.com/pdf/manuals/323354a.pdf .  The terminal pin assignments are listed in Table 1 on page 5.
You can search for any NI product manual at www.ni.com/manuals .
Sean C.
Message 10 of 13
(4,941 Views)
