FieldPoint Family
FieldPoint application crashes but VI works fine?
I have built a field point application that crashes 9 out of 10 times. The vi works fine.
The only way I can get the executable to work properly is to go into MAX and manually start the field point device.
(3,271 Views)
Hello Mark,
Are you getting any error codes before the application crashes? Do you have get a blinking status light? What does your application do? What kind of hardware are you using?
Please reply with more specifics, and I will be glad to help you trouble shoot this issue.
Sincerely,
Sean C.
(3,262 Views)
Hi Sean,
Actually, one of you apps engineers was able to help me. The problem was with the vi, where I had three fieldpoint express vi's wired in parallel. I hooked them up in series and the the .exe no longer crashed. Not really sure what the problem was but it works now.
Thanks.
(3,261 Views)
