FieldPoint Family
not able to measure temperature through field point
Hello
I am trying to measure temperature through field point (cFP-2020) using cFP-TC-120 (@location1).I started configuration of fieldpoint,then under remote systems i created the host nefp1, under which network neighbourhood and cFP-2020@0bank was automatically created.Now when i click on cFP-2020@0bank i get a warning message saying "THE ATTRIBUTE ,RANGE, OR POWER UP VALUE DOES NOT MATCH CURRENT FILE SETTINGS" ,can you please explain help me in fixing it,then when i click on all of them for ex.cFP-TC-120 etc it repeats the same warning message!I downloaded one of the example vi from HELP-fieldpoint example vi website called temperature measurement but it did not work.The other questions that i have is on bank configuration (cFP-2020@0bank) currently the settings are as follows:
Device type : cFP-2020
Address : 0
Nwetwork Watchdog Configuration : Disable for bank ,0 ms
Factory configuration is unchecked
I have configured channel 1 in cFP-TC-120 through channel configuration.
Please advise me in this regard.You can mail me at apaul@utk.edu.
Thanks,i appreciate your help.
Paul
(3,283 Views)
One of my co-workers recently wrote a KB that should help you out:
http://digital.ni.com/public.nsf/websearch/E1E498E83C4CB83B86256F5B00088431?OpenDocument
Reply back if you have any qusetions!
Anuj D.
(3,270 Views)
