FieldPoint Family
Fieldpoint IAK file and new user
i've got the following problem with fieldpoint and the IAK file.
The IAK file for our fieldpoint is stored on the netwerk.
Everytime a new user is logged on I must set the IAK file for this user. This is not practical since any number of user can logon (pc's need a personal logon, general accounts are not allowed)
I tried accessing the ActiveX control for the MAX but this is undocumented and NI is not sharing much info on this 😉
Can this be done automaticly? (for example using labview?)
The software setup is:
Labview 7.1.1
LV Fieldpoint 5.0.1.2010
Paul Konings
(4,788 Views)
Hi Paul,
You can use the MAX configuration VI.
Measurement IO palette >> MAX Configuration >> MAX copy configuration.vi.
You can import a MAX configuration into MAX.
Bas van Dijke
AE, Netherlands
(4,760 Views)
Hi Bas,
Thanks for the info but the VI not in LV7.1.1 (or at least I can find it) but only in LV8.2 (don't have LV8.0 to check).
Due to performance issues with LV8.2 (sluggish performance in large applications, i/o error while saving files) LV7.1.1 is currently our platform.
Paul
(4,752 Views)
Hi Paul,
In Labview you have the Fieldpoint open VI (on the Fieldpoint palette). Here you can select a IAK File Path. With this vi you can load a IAK file for your application.
Bas
(4,720 Views)
