FieldPoint Family
Fieldpoint extended commands for the FP-AIO-600 module
I can´t find a reference about the FP-AIO-600 module in the FP-1000/1001 Programmer Reference Manual. What information and attributes can be obtained from the extended commands for this module?
Thanks in advance...
(3,360 Views)
The [c]FP-AIO-600 module will use the same input ranges as the [c]FP-AI-100 module and the same output ranges as the [c]FP-AO-200 module. Likewise, the channel errors for the input channels are the same as the [c]FP-AI-100, and the output channels use the same errors as the [c]FP-AO-200. The module does not have any attributes. I believe the Module ID will be 0x0123.
Aaron
LabVIEW Champion, CLA, CPI
(3,343 Views)
Thank You very much.
(3,336 Views)
