‎09-29-2011 10:09 AM
Hi, I am using cFP-AI-100 to read the current of my system and determine if the current is above the ideal value. Using the field point i was able to achieve the reading of the current; however, I would also like to display the current as a function of time. So i want to display the current in the y-axis and the time(in secs starting from zero) on the x-axis so i see the change of the current (dI/dt).
I tried using the NI Scope but it does not work as i thought it would. Any suggestions?
thanks
Guillermo
Solved! Go to Solution.
‎09-29-2011 12:15 PM
Nevermind I was able to display the current vs time 🙂
I used a Waveform chart connected to my source instead, and it displays real time values.
