FieldPoint Family
LabVIEW Real Time version and cFP-2120
Does LV 7.0 support cFP-2120 with the new FieldPoint driver?
I haven't found any info on both manual and datasheet.
The customer requiring this info is D'Ambrosio Carlo at CRF and he needs to be calles asap
Thanks so much
ciao
(3,872 Views)
The customer needs to install FP RT SW 4.1.1 which should be available in the package he received.
If the customer does not find it, he needs to contact NI Tech Support.
AlessioD
(3,864 Views)
Hello Wolverine,
If you are using the cFP-2120 controller, you will need to have LabVIEW 7.1 or later.
Eric
DE For Life!
(3,792 Views)
