03-10-2005 12:55 PM
03-11-2005 02:50 AM
03-11-2005 08:33 AM
03-11-2005
11:33 AM
- last edited on
05-08-2026
08:52 PM
by
Content Cleaner
Hi letreca,
When you go into MAX and expand "Remote Systems", do you see both cFP systems appear? What are their status in the right hand side panel (e.g. Connected)? If they're connected, that means you're communicating with them, in which case are you able to monitor their values from "Data Neighbourhood" in MAX? If you can, try running a LV example program to make sure it's not a coding issue. Are you getting a specific error when reading through LV, or just not getting any data?
If you can't communicate with the cFP units through MAX, I want to confirm if you were connected directly from your ethernet card to your cFP module when you had one cFP connected? If so, you probably had the network settings on your computer configured as described below. When connecting through the hub, you may have to reset the network settings of your computer (perhaps back to "Get IP address from DHCP").
Connecting a Fieldpoint Controller Directly to an Ethernet Card [article no longer available]
You can also try resetting the IP addresses of your cFP modules, and testing out the other cFP module independently to make sure they're both functioning properly.
Lesley Y.
03-12-2005 06:33 AM
03-14-2005 10:04 AM
03-14-2005 03:44 PM
