FieldPoint Family
Setting IP address on the cFP-1804
Hello Raymond,
Though this is an older KnowledgeBase article, it is a very useful resource when installing National Instruments software onto your PC.  Please take a look at the article and let me know if you have any questions.
Ching P.
DAQ and Academic Hardware R&D
Message 21 of 25
(4,070 Views)
That was very helpful.  Thank you Ching P.
Raymond
Message 22 of 25
(4,064 Views)
I just hooked up my first ever cFP-1804 to the network, using MAX v 4.2.0.3001 with FP 5.0.3009 and can confirm MAX would not recognize the device.
Updated MAX to 4.3.0.49152 from 3rd quarter 2007 SSP CD's, MAX now sees the cFP-2804.
Glad this thread was near the top, saved me from searching!wink smiley
-AK2DM
Message 23 of 25
(4,049 Views)
Darn it.  I updated to the third quarter distribution as well and I still can't see the CompactRIO.
I thought I would try with cross-over cable but I can't find the Suggest Value button in MAX which is suppose to tell me which Subnet is being used.
I can't believe that there isn't a VI that makes sure that all the components are in place.  Windows is so convoluted that NI should give us a hand to cope with it.
Raymond
Message Edited by RL on 10-25-2007 05:15 PM
Message 24 of 25
(4,045 Views)
Have you tried the following troubleshooting steps for your cRIO?
1, Check the status LED on the controller.It may be blinking occasionally every few seconds to indicate that it is in an unconfigured state.  If the status LED is flashing continuously or solid, it is possible that your controller has an unrecoverable error, and you should contact National Instruments at this point.
2. Switch the reset IP switch and reset the controller to restore the default IP address (0.0.0.0).
3. Disable network firewalls.
4. Ensure that host and target computer are on the same subnet.
Also, try following the steps in this KnowledgeBase article. Let me know if this helps!
Amanda Howard
Americas Services and Support Recruiting Manager
Message 25 of 25
(4,024 Views)
