FieldPoint Family
Trying to make FP-PG-522 generate a 100Hz square wave
I'm trying to create a VI in LabVIEW 7 that will make the FP-PG-522 connected through a FP-2000 ethernet module generate a 100 Hz (variable by the user) square wave signal. The hardware seems to be operating properly; I can communicate with all the FP modules. I'm monitoring the output between terminals 1 and 2 on the FP-PG-522 with an oscilloscope and I have a 12VDC power supply connected between V and C terminals. I believe I must be doing something wrong in my VI. My VI is attached below.
Thanks in advance.
(3,060 Views)
I do not have LV7 loaded yet.
Hear is a link to my question and answer to using the 522.
Note: follow the directions exactly! The attributes all have to be set correctly for everything to work. I also seem toremeber there where some hardware jumpres involved(?).
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=5065000000080000002D550000&UCATEGORY_0=_18_%24_17_&UCATEGORY_S=0&USEARCHCONTEXT_QUESTION_0=FP-PG-522&USEARCHCONTEXT_QUESTION_S=0
Ben
(3,060 Views)
