FieldPoint Family
When I change the dip switches to on, I can't even download my application
In the answer of my last question, You suggested me to change two dipswitches to on. When I did that, I couldnot even download my application. Any other way to enable the abort button in the remote panel?
(3,063 Views)
Suna,
After you remove your executable, you should place the dip switches in their original position and turn the power on, then off again. Then, you should be able to download your application. If you still cannot see the abort button, check the window appearance in the VI properties menu. If the appearance is set to custom, then the abort button may be disabled.
Michael Shasteen
Applications Engineering
(3,063 Views)
