Suna,
After you remove your executable, you should place the dip switches in their original position and turn the power on, then off again. Then, you should be able to download your application. If you still cannot see the abort button, check the window appearance in the VI properties menu. If the appearance is set to custom, then the abort button may be disabled.
Michael Shasteen
Applications Engineering
