08-01-2007 03:16 AM
08-01-2007 06:24 AM
08-01-2007 09:22 AM
If you want to show a picture, make sure you save it and upload it as an attachment. .png format is preferred, definitely stay away from .bmp files. Jpegs are okay, but the compression algorithm can corrupt the image of things like block diagrams slightly. Post the message.
Then if you want to embed it in the body of your message, right click the attachment once it is posted and open in new window. Copy the URL from the address bar. Go back to your message and edit it by selecting the link to the above right of the message. Then click the yellow picture icon. Paste the copied URL into the dialog box. Hit OK and post.
Otherwise, the picture is linked to a location on your hard drive which only you would have access to. Doing it by the above method makes the picture available to everyone, and puts the link to the picture to the NI website storage location.
08-01-2007 02:15 PM
Hi Rodnebb,
I'm not sure completely understand the issue you are seeing, but I will see if
I can help anyway.
If you are seeing the yellow ! triangles next to your I/O modules, this is due
to editing the IAK file associated with the project in MAX. LabVIEW is
dependent on the iak file, and will display errors if it is changed outside of
the project. The iak file associated with the project should be in the
same directory as the project and have the same name as the project.
If you are seeing the yellow ! triangles next to your VIs, this is due to
moving your VIs from their original location. The LabVIEW project references
all items contained in it through relative paths, not absolute paths.
Therefore if you move the VI from its original location without keep the same
directory structure with respect to the project, the project no longer knows
where to find it.
Please let me know if you would like me to clarify anything. Also, if
these are not your issues, please let me know how you are getting into this
state and attach a screenshot of what you are seeing. This may help me
better understand you issue.
08-03-2007 03:30 AM - edited 08-03-2007 03:30 AM
Ok,Message Edited by Rodnebb on 08-03-2007 03:32 AM
Message Edited by Rodnebb on 08-03-2007 03:33 AM
08-03-2007 08:46 AM
01-13-2014 11:42 AM
Can you recall how this was fixed? Seeing the same issue and don't know how to fix it.
