FieldPoint Family
ps-4 power supply
     I plugged AC input terminal connector into the input port on the FP-PS-4 according to OPERATING INSTRUCTIONS. The output voltage is 24 VDC. But the  V output terminals is 0 VDC and C terminals is -23.6 VDC reference earth ground. I wonder whether this output is correct.
     Using this power supply to crio 9103, the chassis ground  is -23.6 VDC reference ground (equal to C terminals). This will result in mistake when my signal is ground referenced.
     Thanks for reply!
Tao
(7,339 Views)
I suggest you should better double check the Ground wire is correctly connected in the AC port. (green by North American standards; green/yellow by
international standards).
(7,303 Views)
thank you.
My AC port ground line is green/yellow.
In addition, i checked the PS-4 module by multimeter, found the ground
terminal in AC port is connected with V terminal in DC port (0 ohm) , regardless of wire.
So, whether my PS-4 module has a malfunction?
thanks again.
(7,285 Views)
I also check a PS-4 module here by multimeter. The ground terminal in AC port and V terminal in DC port are open loop. So I think there should be something wrong with your PS-4 module.
Best wishes!
(7,283 Views)
thanks a lot!
(7,281 Views)
