I plugged AC input terminal connector into the input port on the FP-PS-4 according to OPERATING INSTRUCTIONS. The output voltage is 24 VDC. But the V output terminals is 0 VDC and C terminals is -23.6 VDC reference earth ground. I wonder whether this output is correct.
Using this power supply to crio 9103, the chassis ground is -23.6 VDC reference ground (equal to C terminals). This will result in mistake when my signal is ground referenced.
Thanks for reply!
Tao
