Forum Italiano sui Prodotti NI
annulla
Visualizzazione dei risultati per
Cerca invece
Intendevi dire:
Labview dll calls fails while Labview Run time is already running
Hi All
I developed a DLL by Labview 7.1 which writes a simple file and this DLL is loaded dynamically into another DLL.
Furthermore the latest DLL is invoked by using some VI Panels.
So the scenario is this one
Labviwe Panels --> DLL_A --> WriteFile.dll(built by Labview )
Now it's seems that if Labview is running and I am going to call the WriteFile.dll through the DLL_A nothing happpens.
So I tried to skip Labview and to create a simple test application to check WriteFile.dll and I discovered that Without loading Labview this WriteFile.dll works fine.
What can be the problem? It's seems some problem occurs with run-time engine conflicts.
Please help me
Messaggio 1 di 4
4.089Visualizzazioni
You might want to post this question to the LabVIEW forum.
Messaggio 2 di 4
4.081Visualizzazioni
take a look at the example at the link:
http://zone.ni.com/devzone/cda/epd/p/id/1697
Does it works on your machine? If so, check the difference between this example and your vi.
I hope this helps
Clara
Messaggio 3 di 4
4.065Visualizzazioni
Hi Clara
Yes It's working but I don't think CDF_Example.dll is built under labview.
The problem I have is:
1) Built VI and create its DLL -->DLL_1 ( this one write only a file )
2) Open Labview Panel -->calls DLL_2 that calls DLL_1(see above)
3) the DLL1 does not work
But If I run the DLL_1 from normal MFC console Application( Labview 7.1 run time engine not loaded yet ) the DLL_1 work.
Alex
Messaggio 4 di 4
4.060Visualizzazioni
