GDS(Goop Development Suite)
GDS Classes no more recognized as such. How to fix it?
HI Group,
I want to create a new derived GOOP DVR class but GDS does not list some existing GOOP DVR classes as possible parent. How can I fix that?
I can select the class Entree but none of its parents
However, the class Entree inherits from other DVR Classes:
I have recently converted the project from LV2013 to LV 2015 if it matters.
Any clue how to fix that?
LabVIEW, C'est LabVIEW
(7,998 Views)
Update: After some trials, I concluded that a class MUST be explicitely in the project (not in dependencies) to be in the Select Parent Class list. I find that annoying. Bug or Feature?
(7,906 Views)
It's just they way it always been.
But I could change that and give it a go to see if it works.
(7,847 Views)
That is not the way it is in the native LabVIEW inheritance dialog, hence my confusion. Seriously, I have hundreds of classes in my user library, I don't want to have to include them in my projects just to create derived classes.
Thanks for your support.
(7,829 Views)
I had a similar problem. It could be solved by moving the lvlib containing the classes further up in the project.
(7,692 Views)
