Dear Erick,
Thank you for your suggestion, anyway I try to use NI-FGEN SFP and select the "Standard function mode" but in the triger type I cant select the "Single" I found only "Continuous". Moreove, I try to select other function mode and in the trigger type I can see the "Single", but after I select it and apply input wave in the NI-Scope monitor shows the continuous wave form.
             Regards;
              T.Sahaphol
