High-Speed Digitizers
Independent trigger on 5112
Is it possible to configure both channels as trigger source on a PXI5112. Maybe with an OR-Function.
I need two channels which both can trigger signal aquisition.
Are there any cards available that can do that (similar performance like the 5112)
Thank you
Oliver friedrich
(6,047 Views)
I don't know exactly what do you want to do with your application, but with an OR - Function it's impossible to realise this.
But it's possible to take a Structure Sequence or/and Case Structure!
(6,047 Views)
