High-Speed Digitizers
NI-scope driver is not listed in the labview functions!!
Hi everyone,
I’m using High speed digitizer (NI 5922) and I want to take the data programmatically with the Labview 8.5. my problem is that I can NOT find the NI-Scope driver in the function palette of the labview and I found only one driver with “Agilent 34401” which I don’t need, Although everything is OK with the MAX (the driver passed the self test and I can run the SCOPE SOFT FRONT Panel).
Thank you for your kind concern,
Best,
Ibrahim
(6,556 Views)
Hello Ibrahim,
the current version of NI-SCOPE (3.8.7) does only support Labview 8.6.1 and higher (-> https://www.ni.com/en/support/downloads/drivers/download.ni-scope.html#307032). After a little research the latest supporting version I could find is 3.3.2 ( -> http://joule.ni.com/nidu/cds/view/p/id/883/lang/en),  but you may have some problems when using Win7.
Hope I could help,
Oliver
(6,524 Views)
Hi Oliver,
I'm using NI-scope (4.0) so for sure it might be in compatible with labview 8.5.1, isn't it?
best,
Ibrahim
(6,514 Views)
Accepted by IbrahimSadiek
NI Scope 4.0 isn't compatible with LV 8.5.1 neither, as you can see on this readme:
https://download.ni.com/support/softlib/high_speed_digitizers/niscope/windows/4.0/readme.htm
Minimum requirement is LV 2009 SP1
(6,493 Views)
