High-Speed Digitizers
Problem initializing 5620 digitizer
Trying to run example provided - Getting Started. When niScope_init is executed I get an error - BFFF0011 telling me the "Insufficient location information or ... device not found".
MAX does see the device and for the name I enter the information from MAX - PXI12::15::INSTR. I also tried to set up an alias using rename - same result, same error. At the same time MAX says the device is there, it is fine and I can run the NI-SCOPE soft panel just fine.
HELP!!!
Mark
What can cause that?
(6,893 Views)
It looks like you're using the VISA name for the device.  NI-Scope is expecting an IVI session, IVI logical name, or a DAQ name for the device instead.  In MAX, under Devices and Interfaces, look for the 5620 under Traditional NI-DAQ Devices.  It will have a certain DAQ number.  Use this number in the resource name like the following example: "DAQ::1"
Hope that works.
Patrick
(6,890 Views)
IT DID - thank you!!!
(6,886 Views)
