High-Speed Digitizers
SCOPE Soft Front Panel
Hello DFGRAY:
What is happening? Could you please email me back?
Message 61 of 66
(2,053 Views)
Hi DFGRAY:
I haven't heard from you. I don't know what is happening. I would like to say everyone need luck. Everythings you taught me seems working right now because I tried it in these couples of days. I just need to have some luck. I believe if you can help me, I can continue my project. Don't worry, I will make thing easy. Could you please help me out
Message 62 of 66
(2,037 Views)
I have not replied because I don't know how to help you.  All the questions you are asking have been answered in one form or another in previous posts in this thread.  As I have mentioned before, you need to find a local electronics guru to help you out.  Your task would have been finished weeks ago, had you done this.  You can't learn electronics practice from a web forum like this.  You can learn it from a course or book with the help of a colleague.  I urge you to do so at your earliest convenience.  You will continue to have difficulty until you do.
In any case, this thread has wandered far off the original question and no longer belongs in this forum.  If you have a specific problem you need help with, I would recommend you start a new thread in the appropriate location.
Message 63 of 66
(2,030 Views)
Hi DFGRAY:
I did not get your reponse in another post. I am in an urgent. That is why I post it.  Pls forgive me.
The electron guy does not know DGND.
 After I worked on this hardware in this week. I find I have to ask you what you mean the digital ground (DGND) connection to the fixture. Last time, I did not quite get what you mean and I would like you to verify.
Attached is the picture of DGND and digital input connection. Is this connection correct? I have also attached the block diagram of the fixture with 9V DC Power Supply as an input. Since you know, the negative terminal of the fixture has digital ground under the push buttons part, when connecting the CB 68LP board, do I really need to do anything with it. Otherwise it seem the digital ground is the same as the CB-68LP board after connecting cable from CH1 through CH5 through the fixture. If you look at the block diagram, the CH1 and CH 5 are connected CH2-1 through CH2-5 and the DGND line is connected to digital ground under the push buttons..
Another diagram called diff mode wire. Do you think I need to put I more wire to connected from AI+ to AIGND according to the picture for diff mode?
You said the offset is form by adding R1. Is that because the voltage right now is adding another voltage drop for R1.
You said the bias resistor 10k should add from AI- to dgnd to seperate the ground. Is this setup correct
Message 64 of 66
(1,998 Views)
Hi DGGRAY:
I still have not received your email I don't know why? Do you have anthing happening? I need your help
Message 65 of 66
(1,991 Views)
Message 66 of 66
(1,986 Views)
