Currently the NI-5112 does not have video triggering.  However, since you are testing DVD signals you may already be wanting to in corporate vision test to test the picture yeilded by the video test pattern signal as well as measuring the parametric parameters with the 5112, such as sync pulse width.
If this is the case you can incorporate a vision (frame grabber) board to capture the image and have it trigger the 5112 to acquire the line of interest.  In this manner you can test the video picture quality with the vision board and the analog signal parameters with the 5112.
For more information on NI's vision products visit:
http://sine.ni.com/apps/we/nioc.vp?cid=10014〈=US
If you would like to see an example program which integrates a vision boar
d with the 5112, I could probably dig one up.
Good Luck on your project.
Michael Schneider
