High-Speed Digitizers
What's the best tools (hardware and software) to measure the sound of an aircraft?
We are trying to measure the sound of an aircraft by driving a microphones-equiped van along with the aircraft on the run way. We'll then store the data on datasocket server so that we can display the data in real-time on the web. My question is what's the best tools (hardware and software) for this type of application? Thanks.
(6,142 Views)
I agree with Raecine who posted an answer to the same question in the RealTime catagory. The best hardware solution would be one the the DSA Boards. If you have the option to use a PXI setup I would recommend the NI 4472 which has 8 simultaneously sampled channels with 24-bits of resolution.
(6,142 Views)
A sound level meter is a measuring instrument used to assess noise or sound levels by measuring sound pressure,Often referred to as a sound pressure level (SPL) meter, decibel (dB) meter, noise meter or noise dosimeter, sound level meter uses a microphone to capture sound.
(3,515 Views)
