IF-RIO
NI PXIe-5641R RIO IF Transceiver Example: Integrating the NI PXIe-5641R with the NI PXI-5610
When I use the NI PXIe-5641R RIO IF Transceiver Example,there's a problem that FPGA VI Reference Out can't connect with the HW Exec Ref in as following attachment, in 5641R_5610_upconvert_mode_only_chris (HOST).vi ?
please tell me y?
(7,358 Views)
Which version of LabVIEW are you using?
Are you on a 64bit or 32bit Operating system?
Can you post a screen shot of the error message? (ctrl+h then hover over broken wire)
Did the code ever work?
Was it moved from somewhere else or upgraded to a new version of LabVIEW?
In the meantime, try right-clicking on the Open FPGA VI Reference node, then clicking configure. In the dialog, browse to the bitfile that you compiled. Select the bitfile and hit ok. Hit OK again to close the configure dialog.
(7,347 Views)
hi
please see "NI IF Transceiver GETTING STARTED GUIDE" -> Appendix B: Troubleshooting -> When I Open a Host VI, LabVIEW Cannot Find a File Named filename.lvbit or filename.lvbitx
regards
(7,342 Views)
