IF-RIO
Retry for bit file generation
After the FPGA compile, LV saves the bit file.  For several times, I forgot to check out the bit file from SCC (perforce), and the compiler just exit directly.  If there could be a 'retry' option, much time can be saved.
(6,046 Views)
If you hit the "run arrow" of the FPGA VI, instead of the right-click compile option in the project, it should do what you want.
(6,034 Views)
