Home
Community
Discussion Forums
Additional NI Product Boards
IF-RIO
Topic
IF-RIO
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Retry for bit file generation
Ex-NISH2
Member
07-21-2006
08:14 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
After the FPGA compile, LV saves the bit file. For several times, I forgot to check out the bit file from SCC (perforce), and the compiler just exit directly. If there could be a 'retry' option, much time can be saved.
0
Kudos
Message
1
of 2
(6,042 Views)
Reply
Re: Retry for bit file generation
Mauricio Capistran-Garza
NI Employee (retired)
07-24-2006
08:41 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
If you hit the "run arrow" of the FPGA VI, instead of the right-click compile option in the project, it should do what you want.
0
Kudos
Message
2
of 2
(6,030 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
