Industrial Communications
Communication between S7 PLC and NI Smart Camera over RS232
I'd like to connect a NI Smart Camera with a S7-300 PLC over RS232.
I have a few questions:
  • Did anybody write some S7 code for the communication between the S7 and a NI Smart Camera over RS232, which I can use?
  • Does anybody know the definition of the RS232 telegrams?
    The telegram should constst of a string, which has fixed positions of the separat data values.
    For example, I let the Vision Builder calculate two angles, which should be sent send to the S7. The angle should have 3 numbers before the decimal separator and 2 digits after it.
    123.24 drgrees should be sent as "123.24" and 10.3 degrees should be sent as "010.30", both together as "1232401030" or something like that. But with defined string/byte positions.
    So that I can get the relevant information easily without "parsing" the position where I have to cut the telegram.
    Has the telegram always fixed positions of the data values?
Best regards
Matthias
(7,830 Views)
Hi Matthias H,
there are several possibilities how to implement the required feature: If you're using the Vision Builder to configure your SmartCamera, you could either use Modbus, TCP I/O or Shared Variables.
The main issue the is how to get this data connected to the PLC: I know that there's a Modbus library existing for Step7, but never worked with that. TCP I/O might work if you're PLC provides an Ethernet CP. The easiest way would be to use Shared Variables: You could create and write to this variable using the Vision Builder. You could then bind this variable to an OPC-tag defined on the PLC. The disadvantage of this method is that it requires the use of an OPC server.
Using RS 232 might be quite complicated, as I don't know which protocol the Siemens PLC is using.
Bernd
(7,798 Views)
Hello Bernd,
I tried the Vision Builder and it work's great with RS232.
I can definie the telegram and RS232 is an industrial standard which the S7 can read.
Thank you for your reply.
Regards
Matthias
(7,795 Views)
Hi Matthias,
thanks for the reply, good to hear that it works.
As I did some PLC programming in my previous life, I'm curious about your implementation: Are there any FB's or FC's in Step7 so that you can easily address the serial port?
(7,793 Views)
Hi Bernd,
no, there are no standard FBs or FCs. You have to implement this, but the implementation is not too difficult.
TCP/IP would be much more difficult (but there are several TCP/IP libraries on the NI server to communicate to the S7 PLC if somebody should be interested in it).
(7,791 Views)
Thanks for the info!
(7,788 Views)
