12-05-2010 04:21 AM
I buy a Comsoft Profibus Card, I connect with Siemens S7300 CPU315-2 DP Module.
Below is my configuration in Comsoft Configurator II Window.
The attachements is my PLC side configuration.
You can see from the image above, it is red frame.
Red frame |
Slave is not communicating |
So what the problem is?
The error comes from PLC side or PCI side, or even the cable side?
Thank you for your advise.
02-24-2011 08:33 AM
Try double click the slave to see what the diagnostic says.
DirkW
