04-14-2003 10:22 AM
04-15-2003 08:36 PM
04-16-2003 02:08 PM
12-01-2004 12:13 PM
04-29-2005 09:43 AM
10-25-2005 08:59 AM
Hi Rumcajs
I'm starting working in a project that the objective is develop a system in labview to do the acquisition data from a numerical control siemens 810D using siemens cp5611 profibus card. My questions are: I have a simatic sofnet 6.2 software and you have some examples to set the configuration to cp5611? Is it the profibus interface works together OPC? And what function in labview do the comunication with CP5611? If you have some information about this please contact me. Thank's
Del Conte
11-02-2005 01:12 AM
Hi, Del Conte
I've looked at: http://www.sea.siemens.com/machine/products/cnc/prod_810d.html#1523 and have seen that this CNC consist of Numerical processor, power units and has integrated PLC S7. And there is possibility to connect this PLC to PC through Profibus. I didn't remeber if inside of Softnet exist OPC Server. You can check it in Simatic NET Configuration Console. Siemens doesn't provide any drivers for LV to their CP5611 card. Comunnication idea relay on using OPC Server. OPC Server establish and continue data exchange between PLC and PC. Labview has OPC Client features by means of DataSocked or DSC module to get/put the data. If you give me your PLC configuration (series numbers of all PLC modules on the rack from left to right ,e.g. - 6ES7315-2AG10-0AB0) I can prepare to you connection configuration PLC - PC. Moreover you have to have STEP7 Programming Software and Simatic NET Software to download PLC configuration into PLC.
Regards. Rumcajs
11-03-2005 07:45 AM
Hi Rumcajs,
At the moment I have a cp5611 profibus PCI card and the serial number of this device is 6GK1561-1AA00. I'm not have working with PLC modules on the rack. I just have this module cp5611 equipped with a profibus interface. It is intended for use in progamming devices (PGs) and PCs with a PCI bus interface and we are suposing to use this card in a PC and collect data from this device with LV. I think it's better to us change more information directly via e-mail / msn / skype if you are able to. My e-mail/msn contact is contedel@hotmail.com.
Thank's
Del Conte
