Industrial Communications
Kunbus DF PROFINET IO PCI - Error 12
I have a problem Kunbus DF PROFINET IO PCI.
Unfortunately, I am unable to resolve the problem with the driver.
I switched off all possible devices in BIOS (COM LPT AUDIO LAN),
I removed all others expansion card (NI DSA, X, X-NET)
Still, all I get from windows device manager is the saddest picture like below...
I've checked two cards, two installation discs, different PCI socket always the same result.
NI MAX doesn't see card also...
Any clues?
I will be grateful for any help...
(4,957 Views)
NI doesn't resell the PCi version of Kunbus's Profinet board. I assume there are some specific drivers you need to get the board work with the NI software stack. Please check with the Kunbus support team for help. (support@kunbus.de)
-DirkW-
(4,941 Views)
I've already asked them (a few days ago) but Kunbus support is as silent as the grave...
(4,938 Views)
Ok, l will check with them and hopefully have something by Monday.
-DirkW-
(4,926 Views)
I talked to the Kunbus team and they said they are working on it and have email contact with you?
Let me know if that is not correct.
-DirkW-
(4,905 Views)
Accepted by Jakubek
Yes, they had contact with me.
We managed to find a possible solution.
We are going to swap card PCI to PCIe.
PCI fails because of compatibility issue (Motherboard AIMB-785 from Advantech)
Now I'm waiting for a new card. I will let you know about the outcome...
(4,889 Views)
Do you mind share your final solution to this?
we have several test stands that uses the PCIe profinet card, and have trouble configuring them.
thanks.
-Joe
(3,787 Views)
