04-27-2015 09:34 AM
Does anyone know if the Profinet Slave c-Series module will work on the cDAQ Controllers (with RTOS)? It is explicitly listed as compatible with cRIO, but I cannot find hard evidence that it will work on the cDAQ Controllers.
Wes
Solved! Go to Solution.
04-27-2015 10:25 AM
Hi Wes,
The cRIO PROFINET module requires the use of LabVIEW FPGA. Due to this it is not compatible with cDAQ chassis regardless if they are running a Real-Time Operating System.
