Industrial Communications
read Counter register from PLC (LG) LSIS Master K120S(E) via ModbusRTU
hi guys,
i made program to read the present value of Counter function on my PLC LS K120S(E) via modbusRTU, i have error code  6002
CTR function move to register D1023 that i want to read on myLV,
this is my LV program :
i have make sure that my hardware and software communication is correct (Slave number, baud rate, Com port)
this is the register mapping, am i wrong about the register ?
i attached the manual of PLC LSIS K120S(E)
please help me whats wrong on my program ? thanks....
Message 1 of 8
(9,542 Views)
Hi rhiesnand,
Modbus exception code 2 just means that the data address queried is not allowable on the slave. From what you posted, it looks like your serial settings are not causing the issue.
So, it might just be a matter of making sure you're querying the right register address on the slave.
Andrew T.
"His job is to shed light, and not to master" - Robert Hunter
Message 2 of 8
(9,493 Views)
Did you also tried to read another address and 1 register. Like address 0 ?
You read at 0x3E8 but the screenshot says this is the data at address 0x3FF (1023)
Kees
Message 3 of 8
(9,465 Views)
when i read 0 register the connection is good, no error report. i attach my video
https://drive.google.com/open?id=0B_94Z4CwsTYeb0V4OWxSZTV5X2s
i did  it according the manual, the register D1023 is mapping to 0x3E8, but when i change to 0x3FF it gave error code 6002 too.
i attach my vi,hope you can help me to solve this problem,thanks
Message 4 of 8
(9,455 Views)
thanksfor your reply, i did the correct set up on my plc, you can see my  video.
Message 5 of 8
(9,453 Views)
If the communication is OK it is a user problem and not a LV problem.
I don't have the time to read the manual of almost 300 pages.
Message 6 of 8
(9,442 Views)
I know this is an old post. I have a problem: I have a machine that is about 12 years old with an old plc that I need to get its program out so I can program a new plc. The company that made the machine no longer have a copy of the file but they did have a copy of the plc manual. I was researching to see if any had any idea of how to pull a program and it looks like you have already done it. Could it be possible to share the VI's.
Message 7 of 8
(6,323 Views)
Does the manual contains a chapter with the ModBus commands ?
If there is,is there a command to read to program from the PLC ?
Kees
Message 8 of 8
(6,315 Views)
