6034e card is not appearing in Devices and Interfaces in MAX 9.0.2
Hi
I have 2 NI-6034e  cards installed on a computer in my lab. Previously NI-DAQ was installed on the computer but the hard drive became currupted and the installation was deleted. We completly uninstalled the old version of NI-DAQ (don't remember which version) and installed NI-DAQmx 9.0.2 . Both cards appear in Device Manager (we are running Windows XP) and drivers for the card are installed. However, when I open the MAX program the cards do not appear under Devices and Interfaces. When I try to expand the Devices and Interfaces section I get a DataBase error (KB 42HG08DD). I have turned off the firewall and the NI Configuration Manager Service is running. I have also tried to use install legacy devices option in Tools but a message stating that all devices have been updated appears.
I really only need to be able to use the Data Aquisition Toolbox in MatLab to interface with the 6034e. I am able to register the nidaq card but when I try to  use the daqhwinfo('nidaq') command MatLab produces and error. Any guidance you can provide would be much appreciated.
Message Edited by Irfan Khan on 02-16-2010 11:56 AM
(4,054 Views)
Hello Irfan Khan,
Thank you for using NI forums.  Have you tried the steps outlined in the KnowledgeBase How Do I Clean Corrupted MAX Database and Start With a New One?  I know that it mentions this issue is rare but we can't rule anything out.
(4,030 Views)
see here
then uninstall DAQmx 9.0.2 and install DAQmx 8.9.5
DAQmx9 dropped support for e-series. I'm sure NI recommends updating to a more capable M-series Smiley Wink
(4,027 Views)
B.E.Z. wrote:
Hello Irfan Khan,
BEZ- blue-bars should do better at finding the obvious problemsSmiley Wink
(4,026 Views)
I don't think that chart is correct. For many M series (i.e. 6220), it says the latest is 8.9.5 but the readme for 9.0.2 lists it and the 6034.
(4,022 Views)
You are correct!  I wish the chart was updated !Publish Date: Aug 25, 2009.
(4,017 Views)
